PIP Mode - iPhone 12 Pro Max IOS 14
I’m on IOS 14 on an iPhone using Infuse 6 Pro. On the features it says PIP works however I can’t seem to get it to work? This is one of the reasons I bought the app, it is absolutely fantastic but I can’t seem to get it to work.
Any help would be appreciated.
Thanls
If you don’t get the PIP button then I believe that it is an unsupported format. Unfortunately PIP has to use Apple’s native player instead of infuse.
