I have a problem with playing pictures on the apple tv black using the media player 0.7.1. When I try to play a jpg file it won’t load i get all the time the spinning wheel. I used the tool seasonpass to jailbreak the apple tv and i’am using a wireless network with a freecom nas device.
Hi, i have exactly the same problem with my synology ds 411j. the strange thing is that the slideshow function works fine, but i’m not able to browse the folder. after a half minute “loading content”, my apple tv restarts.
i use the latest version, used seasonpass to jailbreak and have a wifi network.
I waited for 15mins for it to load 1 small Jpeg but still just get the spinng wheel so I think you theory doesn’t work, but thanks for the suggestion anyway.
Yep, OK, they do need to be a lot smaller than that, as small as you can get. I have 2 coppies, so the originals on my PC that are circa 2mb then a compressed version on my NAS circa .2mb
Thanks for all your advise and help but still does not work. I have took the image using a program called ROOT right down to the lowest quality 65KB and various other qualities but still just get the spinning wheel forever. What program/method do you use to reduce the size and I will try that to see if it works.
I can open all the folders and it shows a general icon with the name of the photo but when I select thats when nothing happens. I know they work because I can load them through Itunes but that defeats the object of have a NAS drive
