What is the size required for the favourites and the movie/TV image that gets shown.
Is there a specific format or resolution that works best?
Thanks,
Thanks,
You might take a look at the user guide here Metadata 101 – Firecore Support I believe it has the info your looking for.
Edit to add: There is also references to artwork sizes here Adding Custom Favorite Artwork (tvOS) – Firecore Support
Perfect, many thanks
