PGS subtiles in HDR
I don’t know if this behaviour has already been reported: PGS subtitles in HDR sometimes look quite dark. Strangely this doesn’t affect all movies, in some it looks fine.
I’ve tested the same file with Infuse and MrMC (see screenshots). Note that the camera makes it brighter in both cases, but you should see there’s a difference. For movies without the “bug”, subtitles look exactly the same in Infuse and MrMC.
Anyone seeing this too?
This is a known quirk, for now.
The fix is currently being held back by a bug Apple introduced in 11.3. A bit more info on this can be found here.
FYI, we believe we have found a workaround for this which we plan to include in 5.7.1. :slight_smile:
Great news! Thanks James
