PatchStick failing on BusyBox install using Wireless Connect
Just bought the stick and assembled exactly per instructions without error. It is an IBM 1GB thumb drive. Installer appears to hang after BusyBox install trying to then initialize BusyBox where the command line says starting init.d/rcS.
At first I thought maybe this was an issue with the thumb drive, and then maybe because I was connected via Wireless, but once plugged in to the router directly, the same error occurs at exactly the same spot…
I followed the instructions perfectly and did it once more to make sure.
Anyone had any success with a larger stick made by Sony?
Thanks, Torvant
This problem is typical of a flash drive not being recognized correctly by the Apple TV. Try using a different stick. Kingston and Memorex tend to work quite well.
Howdy and thanks I am trying to locate another drive now. Hopefully it will be one of the recommended ones.
In the meantime, do you have a theory as to what is keeping certain drives from being initialized correctly?
Thanks, Torvant
It’s hard to say what is making some drives incompatible, while others work just fine. The install script formats all the drives the same.
Take a look at:
