Password Alpine is not working.....
Is there any another password. I am using Putty to log into Apple TV but it says Access denied.
Does this mean that my Apple TV2 is NOT jailbroken?
If you get the login prompt then you should be jailbroken.
The username/password combination is root/alpine.   Note that both of these are case sensitive (i.e. they must be lower case).
It was very stupid…
I used sssh root instead of only root…
Now it is working.
