Parental controls
Hi all,
I am trying to set up restrictions on my Apple TV using Infuse with Real Debrid WebDAV.
I have enabled the password, but it doesn’t matter what selections I make to the rating check boxes, it doesn’t ask for the password.
Any suggestions?
You may try adjusting the ‘Require PIN’ option. Setting this to ‘Every Play’ will be more strict and require a PIN for each different video that is played. Having this set to ‘Every Session’ will require a PIN once for playing videos during that particular time Infuse is open.
I would also double-check to ensure the videos you are playing have metadata fetched from TMDB with an age rating present.
