I have enabled Parental Controls in the Settings menu, and I have made sure only the ratings I want to be watched are checked for both TV and Movies (only TV-MA and R are unchecked).
However, when I go to play a movie that is rated R (US ratings), even though that option is not checked it still plays without asking for a passcode. I checked the movie display card to make sure the movies display the ratings and they do. Same with TV shows that are TV-MA.
I can set a folder specific passcode (with the long press) and that works, but even the TV/movies inside don’t ask for a passcode.
I tried rebooting the Apple TV and the same thing happens.
This is on a 4K Apple TV, with Infuse Pro 5.9.5 (2442).
Any suggestions or help would be much appreciated!
I just tried a duplicate of your settings (TV-MA & R are unchecked) and it works as advertised for me. When I hit play on a movie that is R it asked for a pass code and the same for a TV show rated TV-MA.
Not sure what to tell you. How are you connected to the shares that the movies are in? SMB, DLNA, Plex, etc.
If you choose a movie/tv show or a folder that is password protected and enter the password, it will not ask you for your password again until you completely get out of Infuse.
This kind of defeats the purpose of Parental Controls, since I have to manually make sure to close Infuse after watching anything that was protected. If I unlock a PG-13 movie for my 12-year old, he can immediately exit out and go watch any R or TV-MA show.
The password should be required each time you try to watch any restricted content. Otherwise it’s useless.
