In Infuse 6 could you make parental controls slightly more powerful by adding whitelist folders so that kids can only access one specific folder(s) and you need the passcode to view the entire library. The rating system is frustrating because I don’t want little Timmy to see all the available movies and then click on a bunch he can’t watch until he finally gets to a rated PG one.
Could you use this? Parental Control for Folder
Also for future reference, there is a forum section dedicated to suggestions here https://firecore.com/forum/suggestions
An even better option would be profile support. Then you could just set up a profile for Timmy that would only show him certain items/libraries. Plex profile support would also be awesome.
This should make your day then! That’s listed here in the “Upcoming Features” Upcoming Features (updated 12/19/23) found in the “Suggestions” forum.
You guys gotta quit it with the whole listening to your customers and implementing wanted features.
Can’t stop, won’t stop.
