So the UK version of that is
h***s://www.paramountplus.com/shows/mobland/video/q36DG76XjlO6j3x0EnmORcxzjlzv7HaX/mobland-stick-or-twist
This gives me the error Failed to open url
As does James example
h***s://www.paramountplus.com/shows/video/q36DG76XjlO6j3x0EnmORcxzjlzv7HaX/
I’ve deleted Paramount Plus,restarted the Apple TV,tried the STRMLNK from Google Drive and local NAS all give me the same error.
Both links work on IOS
I’ve submitted a diagnostic
Code
2X8B8
It looks like Paramount Plus has a separate app for GB (and maybe other countries) so it’s possible they are using a slightly different linking format compared to the US app.
If you look at the photo in the first post it always says failed to open url: pplus:// regardless of if I put the pplus:// part at the beginning or not
