Own metadates
Hello
how can i set in infuse my own metadata?
i have tv shows with no metadata in the internet .
Thx
Steve
First, where are you looking for the metadata on the internet? Infuse uses TMDB for the source of metadata but if the files are not using specified file names it may not find it.
Second If you can provide a few samples of file names you’re wanting metadata for we may be able to help.
If none of this works you can follow the users guide for creating local metadata.
Also in general this users guide will give you a good base of info on how to name your files and how to organize them.
