Hi all! So, long time user of MrMC, decided to try out Infuse too today, pro version. Everything looks quite good for all kind of files from SD to 4K HDR remux on my LG B7 Oled apart from the 4K videos from my Samsung S8. MrMC on ATV4K and VLC or MPC HC on my Asus 4K PC monitor show more realistic colors (although Samsung’s saturation in pics and videos is known) but Infuse takes it even further, showing reds and pinks for example way oversaturated. I don’t know if this oversaturation affects movies and tv shows (locally streamed from my NAS via gigabit LAN), I haven’t noticed anything so far but is this something to look into? Maybe a codec issue? Thanks for your time!
I don’t think we’ve had any similar reports, but we’d love to take a look at one of the videos that is giving you problems to see what is going on there.
If you have a chance, you can use the link below to upload a sample.
Thanks for the quick reply. I am uploading one of the videos, it will take some time my uploading speed sucks. Filename 20180728_094005.mp4 on your dropbox link. Meanwhile, here is the MediaInfo of the file:
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42)
File size : 197 MiB
Duration : 34 s 106 ms
Overall bit rate : 48.5 Mb/s
Encoded date : UTC 2018-07-28 06:40:40
Tagged date : UTC 2018-07-28 06:40:40
xyz : +40.6699+022.9121/
com.android.version : 8.0.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Source duration : 34 s 127 ms
Bit rate : 48.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 30.000 FPS
Minimum frame rate : 18.390 FPS
Maximum frame rate : 30.748 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.193
Stream size : 196 MiB (99%)
Source stream size : 196 MiB (99%)
Title : VideoHandle
Language : English
mdhd_Duration : 34106
Thanks again!
Hi! Maybe some update on that? Tested it again with latest beta too, had the same issue.
Got your sample, and a quick test shows the color displayed by Infuse is consistent with other player apps (Apple’s Quicktime, VLC, MPV, IINA).
However, I agree the colors do look a bit unnatural. We’re going to take a deeper look to see if there is a Samsung-specific flag we’re missing, or if it’s just how the video is encoded.
Great thanks a lot for your time on this matter!
