Sure I use XML files, but the show is not recognized (only as multiple Videos, not as tv show), because it is not online at thetvdb.
How I can I create a show for myself?
I can overwrite the description etc but not the S1 • E1! I want remove it, just the title without S1 • E1!
Is it possible?
If you prefer Infuse to treat them as movies instead of TV shows you may try renaming them with a generic name instead of something that includes season/episode info.
E.G.
Big.Bang.Theory.1.mkv instead of Big.Bang.Theory.S01.E01.mkv
Yes, but if I rename the files to a non-tv show name, the episode thumbnails are rectangular (upwards), but I like to have the episodes in the normal view (diagonally)!
We don’t have any plans to support this, but if you have videos from a series that is not listed on the TheTVDb you might consider creating a new series at http://thetvdb.com
This would allow the series details to be accessed by yourself and others.
I think you misunderstand again.
I would like to override the S/E portion of the title for TV episodes.
Even with a self created show at thetvdb it’s not possible for me to change the S/E portion of the title!
