There was a series called Firefly (you might have heard of it) that Fox aired out of order. I would like to display the metadata, however, TheTVDB is listing the episodes in air date rather than in story order. For many older series this doesn’t matter, but Firefly has a narrative arc and the order of the episodes matters.
If I understand correctly, my only options is as follows:
- Set the folder containing Firefly to use local metadata
- Create a local metadata file for each episode replicating the information from TheTVDB
- Name the episodes in story order rather than in air date order
Is that correct? If so, can someone please provide a metadata template for this use case? The sample movie template provided in metadata 101 doesn’t seem like it would apply here.
Also, if there’s an easier way to do this, I’m all ears.
