Output received: check_context failed Error
I am trying to get an ATV2 working again with Seasonpass.
I did jailbreak it last year and it wored well but it will not work now.
First I tried to do my normal tethered boot which failed.
So then I updated iTunes and Seasonpass to latest versions and it still fails when I try to connect or make new ipsw.
In the logfile I see:
DateTime: 24-02-2014 20:54:10 Message: Application start
DateTime: 24-02-2014 20:54:10 Message: Seas0nPass 0.9.5.15470
DateTime: 24-02-2014 20:54:10 Message: clean up
DateTime: 24-02-2014 20:54:13 Message: Started iTunes exe search
DateTime: 24-02-2014 20:54:13 Message: Using registry view Registry64
DateTime: 24-02-2014 20:54:13 Message: Opened HKEY_LOCAL_MACHINE registry key
DateTime: 24-02-2014 20:54:13 Message: Opened HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall registry key
DateTime: 24-02-2014 20:54:13 Message: Found 69 subKeyNames
DateTime: 24-02-2014 20:54:13 Message: Found iTunes in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{96B53CA8-5ABB-49D8-96F1-F6C0D73A76C6}
DateTime: 24-02-2014 20:54:13 Message: Path to iTunes is C:\Program Files (x86)\iTunes\iTunes.exe
DateTime: 24-02-2014 20:54:13 Message: Installed iTunes version: “11.1.4.62”. IsCompatible? True
DateTime: 24-02-2014 20:54:22 Message: Started version check
DateTime: 24-02-2014 20:54:23 Message: Seas0nPass version is OK
DateTime: 24-02-2014 20:54:28 Message: ECID process starting
DateTime: 24-02-2014 20:54:29 Message: Output received: check_context(00000000)
DateTime: 24-02-2014 20:54:29 Message: Output received: check_context failed
DateTime: 24-02-2014 20:54:31 Message: Output received: check_context(00000000)
DateTime: 24-02-2014 20:54:31 Message: Output received: check_context failed
DateTime: 24-02-2014 20:54:33 Message: Output received: check_context(00000000)
DateTime: 24-02-2014 20:54:33 Message: Output received: check_context failed
DateTime: 24-02-2014 20:54:35 Message: Output received: check_context(00000000)
DateTime: 24-02-2014 20:54:35 Message: Output received: check_context failed
and it keeps going.
So I get an error but when I search and google for it I do not find anything of value.
Any ideas?
I have the same problem. Do you find a solution for this??
Thankyou
