“Other” media (not films nor episodes)
Hi there
I use Infuse in library mode with Jellyfin.
It’s been a few days that in Library I get 2 files that are “other”, next to the count of Movies and Episodes.
Maybe there’s some error in the management of my media, but is there a way with infuse to find out the name of the 2 files in question ?
Thank you !
Which device?
Any device, phone or Mac or atv I get the same results
Jellyfin is on a windows server
If you go to the Library and select other you should see the two files there and see the file names.
Thank you. Found it. Well, interesting usecase for you too I think.
It’s a movie that is in two parts. While officially not supported, after trial and error, I found a naming convention that works: Infuse shows me Part 1 and Part 2. So they appear in Movies but ALSO in Others.
Is it normal?
Can’t really help you with Jellyfin, I run just Infuse and it disappears from “other” when you fix the file names.
Thanks nevertheless. It works, it just appears twice. Not big deal
