OSX 10.8 finishes jb but atv2 is not actually jbkn
With seasonpass not working in windows, I decided to run osx in a VM, the process finishes successfully with the latest SP, but when I plug in the atv, its not actually jailbroken. Any idea?
[quote="WinSpecToR"]
[/quote]
Did you check the log as per firecore's suggestion (Help > Show log in Finder)
Hi ponta005,
two things:
1. Could you edit your duplicate posts to something shorter? maybe "delete"
2. It looks like seasonpass created a AppleTV2,1_5.3_10B809_SP_Restore.ipsw... is it possible to do a shift+restore in itunes and select that file to see if it jailbracks it?
[quote="Carpenter940"]
Hi ponta005,
two things:
[/quote]
I've done that before. Doesn't work.
Sry dont know how to delete tiered
hmmmm
Hnmm
i have same problem and i think i know what it is.
the apple tv never gets restored it skips the uploadoing paches and restore
here is my log after many tries  http://firecore.com/user/147986
found this. and when i restore with sp ipsw i get error 1604 i even tried ireb
Setting to i2014-08-02 14:03:59.023 Seas0nPass[1393:5513] dfu entered with status: -1
2014-08-02 14:03:59.024 Seas0nPass[1393:5513] failed to enter dfu, bail!
2014-08-02 14:03:59.024 Seas0nPass[1393:5513] forced: 0
2014-08-02 14:04:00.179 Seas0nPass[1393:5363] ERROR: Unable to discover device mode. Please make sure a device is attached.
2014-08-02 14:04:00.215 Seas0nPass[1393:5363] NOTE: using cached version data
2014-08-02 14:04:00.267 Seas0nPass[1393:5513] restore failed with status: 255
2014-08-02 14:04:00.267 Seas0nPass[1393:5513] restore status false (could be false positive)!
I just bought a Macbook Air (used).  It came with os 10.7.  i could not get seasonpass to jailbreak my apple tv 2.  i then upgrade to os10.9.4 and now i can jailbreak it.  just thought i would share what my experience was.  i used seasonpass 0.9.5
FYI work around found (and I can confirm it works):
http://forum.firecore.com/topic/12385
