Original aspect ratio vs display aspect ratio
if i have mkv files like this
Video
Format : HEVC
Format profile : Main 10@L5@Main
HDR format : Dolby Vision, Version 1.0, Profile 5, dvhe.05.06, BL+RPU, no metadata compression
Codec ID : V_MPEGH/ISO/HEVC
Duration : 44 min 2 s
Bit rate : 18.6 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 1.897
Original display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.093
Stream size : 5.71 GiB (96%)
Default : Yes
Forced : No
Color range : Full
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : IPT-PQ-C2
what will infuse use, is it display aspect ratio or original display aspect ratio? i use mkvtoolnix to set it and use ffmpeg to detect black bars. i usually use set aspect ratio on playback but there’s no 1.897 option on infuse
