Organising libraries
Hi there :slight_smile: I’ve started to use infuse recently and it is a great player but I miss one thing from Plex: the ability to pin my libraries on the Home Screen, for instance I have a series folder, movies folder and kids folder and with infuse for me to acess the kids folder I have to open the “server” icon and in there select the kids section, as in Plex I can pin those folders and acess them directly on the main menu, can I do this with infuse?
You can do the same thing in Infuse, follow the “Add Favorites” section of this users guide and it should be what you’re looking for.
Worked like a charm!
