just downloaded alpha 8, I found a weird bug, when I open the app, and try to play a file it plays as stereo, but when I skip back or close the play, it only plays mono.
Also when I play next file (autoplay in TV show) or close and open the same file, it plays mono again.
Tested again with 3452. First I tried Coco and it worked! Got just static with Avengers Engame, SpiderMan 2. Played Coco again and it failed with static. All are TrueHD 7.1.
Like @robkewit âWhen moving to the next episode or skipping with the left/right arrow, the audio pops and then the right speaker goes mute.â
Itâs the same for me, big issue (not in Alpha 7, I have roll back) and itâs worse with my bluetoothâs HeadPhones (QC35 II), big noise on the right speaker.
App Version : Alpha 8
My setup : MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports) ; Big Sur 20D74
No problem with this codec :
@james A request :
An âinformationâ display panel for the media being played would be nice (especially in developer mode). With the name of the file, the codecs used, ect ⌠(Command + i)
You may want to give details of what youâre seeing since there are multiple problems earlier in the thread so weâd know for sure what specific problem youâre facing. If itâs the same as a recent post you could also use the âReplyâ button on their post.
I have audio issues too when skipping in a video with a TrueHD 7.1 audio track. Sound in the remaining speaker distorted, or low volume in 1 speaker and popping sound in the other. No such issues with the previous alphas (as far as Iâm aware!). If I switch to the DD 5.1 audio track I have no issues. 15" MBP 2015
