Since last update OneDrive pro doesn’t work neither at the phone
Welome to the forum!
Can you provide a bit more info about the issue you are seeing?
Are you have trouble browsing files in OneDrive? Playing certain files?
If you’re able to send in a quick report from your device it might help track down what’s going on.
