on 5.2.1 confused if I could jailbreak or not
I am terribly sorry for this, I looked around but not clear yet as to what I can do...
Basically I am on 5.2.1 and not sure how to go about jailbreaking or if I could still do it.
I have saved my shsh blobs using ifaith and seasonpass.
I try using seasonpass but it fails to download every time the apple 5.3 firmware.
I am stuck there. I downloaded it separately anyway from another site but I don't know how to direct seasonpass to check for it instead of trying to download it....
I am just not sure what to do next.
Last time I had this jailbroken was ages ago and now that I decided to do it again, I am rusty and I admit my time is limited. So if anyone is kind enough to let me know what I am doing wrong I would appreciate it.
And yes, it's an apple tv 2 and I can also get to dfu no problem...
Thanks.
I'm on a PC and this is where my downloaded firmware is:
C:\Users\[USER NAME]\Documents\Seas0nPass\Downloads
Replace USER NAME with your name and place the firmware there. Seasonpass should see it and go from there.
Thanks, worked as far as starting to patch it, but it fails to download the signatures...
it says check your internet connection and firewall settings...
pretty much what was going on before when it was trying to download the firmware...
what next ?...
I have the same issue. Anybody could suggest?
