OK half way there!!
ok so afther days trying this out..
this is what i did..
used this to restore to 4.0
then try the ssh(winscp and putty for me PC)
all good it loads no prob.
uploading now
afther incase i used limerain (newest version)
http://limera1n.com/
and then hooked it up to my tv and run the app (aTV flash black
then it rebooted and voila it was done.
now the issue is..
when i try to install the apps in maintenance it says install failed??
