Trying to figure out how to label each episode on my PC for infuse on my apple tv. Tried listing them 1,2.3 etc, the e01,e02 but they still just show up as 5 instances of O.J. Made in America without a way to tell which is which. Any idea?
Sorry but this is a single movie, not a TV series. All of the official websites show it as a single movie.
Best thing to do for the time being would be to create a playlist of the parts you have in order and run it that way. You could also create individual nfo files for each part and show it that way.
I have mine as episodes as well. It makes no sense that TMDB categorise this as an eight (8) hour movie !!!
Not just TMDB, it’s all of the standard references. It was the last movie to win an Oscar with that long of a play time because they changed the standards. It was originally screened as a movie first without an intermission and then with one or two intermissions.
I don’t think I’d be getting the large soda for that one.
Even the big bucket of popcorn wouldn’t last
But it’d make a dandy Emergency Rest Stop.
Wiki says it was released as a five part mini-series and theatrical format at the same time
O.J.: Made in America premiered at the Sundance Film Festival on January 22, 2016,[3] with one intermission,[12] and was also screened at the Tribeca Film Festival on April 23, 2016,
The first part debuted on television on June 11, 2016 on ABC, followed by parts two through five airing on ESPN on June 14, 15, 17 and 18, respectively.[12]
TMDB also has it listed as a series.
And I did a search on that and it only came up with a movie the first time and now it’s there. James did you do a wizard thing on it? ROFL
Well, in that case @SERPIC0 you should be able to list each episode as “O J Made in America S01E0X.mkv” and it should work. Just replace the “X” with the episode number.
Just checked my Infuse setup and it has categorised into episodes with correct metadata. Hooray!
Ahhh ok this was my next guess, I didn’t add the S1 beforehand.
Is there no way to get it to display just Part One- Obsessed with Fame? or will the S1E1 be visible.
Thanks for this!
Yes thanks, was trying to figure out how to get it to display Part 1 etc but this is a good fix too thanks.
