Hi I use infuse with my seagate wireless plus drive. It worked well at the start to find all the videos on my device and the metadata however it isn’t showing up anything new that I add to the drive, even if I disconnect the drive so it has to reload all the files. Is there a manual way to make infuse check for new files (other than pulling down to refresh)
Sometimes after I close the app and turn off the device enough some show up but some never do
