Not syncing watched status
Hi. I just want to say I love the Mac app (and the others, too.) My system: media files stored on Apple Airport Extreme with external hard drive, Apple TV (4th Gen), iphone, macbook pro.
When playing shows on the Apple TV, the watched status updates on the macbook but not the other way around. When I watch an episode on the macbook, the watched status does not updated on the Apple TV (even if I make sure to cycle the sync function on both systems.)
I believe you need to use Trakt to sync watch status.
Create a free account on Trakt.tv and use it in Ifuse on all your devices.
Trakt sync is turned on in the Mac app but syncing of watched status updates only in one direction, from the mac to the apple TV but not visa versa.
Franklin Seal
Ha! Problem fixed.
Even though I did have Tract turned on in the syncing preferences tab, I also had iCloud checked. By unchecking iCloud, the problem resolved.
Franklin Seal
