Not showing collections with Jellyfin
Infuse dosent seem to group movies into collections when using Jellyfin
example:
CleanShot 2022-01-23 at 16.32.18
Collections is enabled and “library - Collections” is empty
Did you check to make sure that the “Collections” option was selected in the settings?
(Also I changed the name of your thread to be “Not” instead of “Now” since that seemed to be what you were after. :wink: )
Edit to add: What version number of Infuse are you using?
Yes collections is enabled in the settings
Using the latest: 7.3.2
Can you check to see which version of InfuseSync you have installed on your Jellfyin server?
Have you tried restarting your Jellyfin server?
Version: 1.4.1.0
Yes i have tried restarting
bumping this
Update:
Seems there was an issue with jellyfin that was causing the issue and now fixed.
But now only some collections are showing in infuse (Bad boys for example):
