Not connecting to SMB while VPN activated
Dear Firecore Team,
on my iPhone I am unable to connect to my SMB NAS (192.168.178.X) while simultaneously connected to a VPN. If I disconnect VPN I can connect to SMB NAS again.
Connecting to the same SMB NAS via the app “Files” or other apps works.
Thank you for your help.
Are you connecting via IP or name? It could be a name resolution issue. Ensure your NAS has a static IP and connect that way.
Thanks for the tip.
NAS has static IP and I setup Infuse to work with IP instead of the name. (SMB v2)
I haven’t tested this fully but I noticed that Infuse failed again in a different WiFi away from home (VPN connected to home) but a competitor app did fine… :cry:
