HI,
I have added a share from my pc.I am able to view the files directly in the share but i am unable to view the files which are placed in folders inside the share.It says “Access denied,Error”.Any solution for this
Are you using a username and password to connect?
If these are left blank, then Infuse will attempt to connect as a guest which may not allow you to access all your files.
