No works Infuse 6.4.1 is no longer functioning on all devices
Version 6.4.1 has been updated and Infuse does not initiate closes.
The same thing happened at Appletv this morning I couldn’t use Infuse.
Good thing I have the full version of Infuse V5 and it works perfectly.
But version 6.4.1 is no longer functioning on all devices.
Any solutions?
You don’t test the versions before you put them up to AppStore!
Mod Edit
Please discuss here.
Same problem here, on iPad and AppleTV.
We need decent local metadata support so we don’t have to wait keep waiting for Infuse to be fixed every time a serious bug gets shipped.
I don’t understand how you don’t test it before!
It doesn’t work on any device even in other people.
It doesn’t work for anyone!
Now wait for AppStore to pass an app and let Firecore know how to fix what doesn’t work.
Please upload 6.4. I don’t want 6.4.1!
Don’t install the 6.4.1. It crashes constantly and can’t be opened. iPad, and also AppleTV
I installed as it was meant to fix the missing artwork problem we have been experiencing since.
This is pretty bad… and illustrates perfectly the need for much better LOCAL METADATA SUPPORT so we don’t have to wait days for a fix and hours for library scanning every time FireCore ships a bug that trashes the metadata.
PLEASE PUBLISH FULL SPECS FOR SUPPORT OF LOCAL METADATA!
AND FILL THE GAPING HOLES IN TV LOCAL METADATA SUPPORT!
Please! No more new features until you sort this out properly.
