No Sync of Watched Status for complete Season
Hello,
I activated iCloud sync so that my iPad and Apple TV 4K is in sync, especially with my watched status. However, I noticed a sync problem if I set the watched status for a whole season on my Apple TV 4K. These watched status settings won’t be synced correctly and I can not see that the season is already watched on my iPad. Is that a general problem? If I set the watched status for only an episode, everything works and the watched status is synced properly between tvOS and iOS. But not for a complete season.
In addition, I can not find any way to set a complete season to watched on my iPad/iOS. Is that not possible? If not, please add this feature. Otherwise, it is frustrating and time-consuming. Furthermore, please add a possibility to set the watched status for a complete series (including all seasons and episodes).
Best regards
GloomyEye
Watched status are currently synced through Trakt.tv, and a bit more info on how this works can be found here.
Hello James,
thank you for the information about the sync option. I will try this.
Could you answer also the other question? I can not find the setting to set a season to watched in iOS.
Best regards
GloomyEye
