no space on device... ATV2
I am trying to update XBMC . Plex and others…keep getting the “installation failed” mssg
Log says “no space on device”
Is there an easy/no brainer fix?
thanks
I had the same issue - submitted my log and was told to re-jailbrake.  I did try  a couple things - i tried emptying the metadata ( i think) - and that actually for some reason let me update i think nito and xbmc or nito and something else but then i got the same no space error and couldn’t get any further - I ended up re-jailbraking (sorry, not the answer you were looking…pain in the ass)…anyways - no problems since i did that.  worth a try though but firecore stated doing what i tried shouldn’t have been enough to make a difference memory wise…
