No sound with specific Atmos audio track
My daughter warned me of a movie (nothing special, 4k, eac3 atmos 768k) that’s silent in Infuse (works with Plex). She’s using the iPad AppeStore version, I tested with this beta on Mac and Apple TV (26 for all) [fine in vlc too].
Should I privately share the movie, run ffmpeg … or push a diag?
That wouldn’t hurt and maybe run the video through mediainfo and post the results here? Is your daughter running the Pro version? (Maybe have her double check to make sure it’s on Pro) It almost sounds like it’s a Dolby version that Infuse doesn’t support with no fall back track. VLC isn’t bound by copyrights for codecs so that may be the difference.
She is and I am. It’s a very common release. It works fine with Plex (Web & AppleTV).
General
Unique ID : (0x)
Format : Matroska
Format version : Version 4
File size : 19.5 GiB
Duration : 1 h 48 min
Overall bit rate : 25.7 Mb/s
Frame rate : 23.976 FPS
Writing application : mkvmerge v92.0 (‘Everglow’) 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1
Video
Format : HEVC
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile B, HDR10+ Profile B compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 24.9 Mb/s
Width : 3 840 pixels
Height : 2 076 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.130
Stream size : 18.9 GiB (97%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1 449 cd/m2
Maximum Frame-Average Light Level : 235 cd/m2
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 596 MiB (3%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Dialog Normalization : -31 dB
compr : -0.28 dB
dialnorm_Average : -31 dB
dialnorm_Minimum : -31 dB
dialnorm_Maximum : -31 dB
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 42 min
Bit rate : 71 b/s
Frame rate : 0.263 FPS
Count of elements : 1613
Stream size : 53.7 KiB (0%)
Language : English
Default : No
Forced : No
We have seem some out-of-spec Atmos samples that Apple devices are not able to handle.
To workaround this you can try disabling the ‘Dolby Atmos’ option in Infuse > Settings > Audio.
Most other apps don’t actually support Atmos so that is likely why the issue doesn’t appear there.
Extracted and confirmed with QTPlayer (using AirPods). Thank you for the tip.
Grabbed another release, merge the tracks and notified upstream.
