No Sound with HDMI transfer
There is no sound with iOS 5.5 update when connected to a display via HDMI. Please fix. Thanks!
Can you try disabling the Dolby/DTS over HDMI option found in Infuse > Settings to see if this makes a difference?
Are you on the iOS 11 public beta by chance?
That worked, thanks! BTW, I’m on 10.3.2
