I have installed in the APPLETV4 both 4pro and 5pro.
In Infuse 4pro library appears in newly added all but in 5pro does not appear.
If it appears in the list but not in the recently added section also does not cool well the seen itrack.
I hope to refresh the library but they are only in the order that you stay when you install it the first time.
Also in library section series do not appear all.
But if I enter one in one in the directory then if they appear in library/series.
Infuse’s version 5 is fairly unstable.
All of the above it does very well the version 4pro appears in recently added everything new in 5 Pro does not.
