Guys,
When using Boxee, most of the control is through the apple tv remote as you would expect. Some tv shows however require a mouse pointer to click a play icons that appears in the Center of the screen to begin playback (not selectable via the remote) An example of this is with Peppa Pig. When running Boxee on the PC the mouse pointer appears at this stage. Does anyone know if I pay £5.49 for ‘Remote HD’, if it will enable a pointer on Boxee at this stage?
Cheers.
