Im not sure where to go from here, I jailbroke my TV and installed aTV black. I was told I should see a change in the menu of the ATV2 but I cant find any change.
Any tips on what to do next? Is it installed properly? How can I watch my video files?
I just bough it so Im guessing it will be the latest version?
I just did a restore of the factory settings and will try to jailbreak it using greenpoison instead of the first one I did.
I mannaged to JB with greenpoison twice by going into DFU mode with the menu-down and then menu-play commands, but it didnt change anything. I made sure to wait 1 minute after it was done to make sure it was properly loaded. Didnt work so Im going to try it again now from the restore.
I tried finding my ATV2 ip earlier, but its only said DHCP and then a five or six digits. What do I type in to get ssh access? What do I need to be able to stream from my MBP? NitoTV, Plex og XMBC? What would you advice me to go for?
