I don’t see the maintenance menu rather. Its not on the second row and won’t appear if i restart it. i’m using the 2nd generation ATV. I do see the FC settings. Did i miss something?
Thanks of rthe prompt reply Not sure what you mean? but I would like to play my home movies from airport extreme like before. I used to go toy my files then select my HD. The screen looks different now and can’t see the way to select my media. Did i miss something? What steps to i need to do?
Also i couldn’t get the work the new flash so i used my older AppleTV2,1_4.4.2… would that cause any problems. Seams to work ok but can’t access my HD.
I’m having the same issue. I had a good jb the other day and got the maintenance icon and was well into setting up everything, but the SSH would not connect. One theory was a virus, another theory was different. Anyways, I re-jailbroke - itunes said it went well. I went into the atv starting up - and i had a firecore logo on the top right row of icons - but it just had the basic apple tv stuff in there - “about”, ‘computers’ audio/video etc…
No maintenance menu at all on the home screen (yes, I tabbed down - nothing). I rejailbroke again, and its still not there. Funny thing is, I can SSH into it at least.
Anyways, I will try again tonite from my windows xp (i used windows7 for these go’s at it -doubt it is related, but I’ve never had a jb issue with my xp, so what the heck, I’ll try it).
Is there some sort of signature on seasonpass that tells the computer its been used once ie: do i need to redownload it everytime i rejailbreak or is it as long as you have downloaded the most current version, you can use it over and over (i’ve tried to word that so it makes sense, I hope it does but it sounds off).
You mentioned re-doing the jailbreak, but not re-installing ATV Flash? It is the installation of ATV Flash that adds the Maintenance menu - not the SeasonPass jailbreak.
You can file that under “Stupid Questions” for me. Sorry, you do something enough times and think you know what you’re doing and then … you don’t : ) Sorry again.
