No "maintenance" menu after GP JB, tried 3 times
Iver jailbroken with Greenp0ison and tried 3 separate ATVFlash installs from two separate computers. Neither of them work. Ive tried rebooting after and reboot lowtide. If anyone has any ideas please let me know.
Otherwise it works fine.
When you install ATV you have to put your appletv set to the in theaters menu…don’t know if you did this!
same thing happened to me - took ages for it to show up but it was installed.
I ended up installing all the firecore packages manually in Terminal via SSH and it then showed up on ATV menu.
Terminal commands are:
ssh root@YourATV2.IPAddress
alpine
apt-get update
apt-get upgrade
apt-get install com.firecore.lastfm
apt-get install com.firecore.couchsurfer
apt-get install org.xbmc.xbmc-atv2
and so and so forth.  Then restart Lowtide with
killall -9 AppleTV
If you're not comfortable with Terminal then don't bother going near it.
Update NitoTV, and under Install Software, click on Update All.
hi there,
i spent the whole morning jailbreaking, installing, failing...
then i did following:
1) Jailbreak with greenpois0n RC6
2) install atv flash (via Mac)
3) NO Maintainance menu visable
4) Open nitoTV
5) Tab "Install Software" > Install XMBC-ATV2
6) returning to mainmenu the Maintenance menu is THERE.
let me know if it works for you as well.
