We have offered an Apple TV to our father today.
Everything is ok except that we don’t have any library. Indeed, we access to the files through the network,
we can see / add the TV shows & movies folder as favorite but the library remains empty.
Any idea ?
KS
If you’re connected to your shares via DLNA/UPNP the library won’t work. Try SMB.
If you aren’t using DLNA/UPNP you have to let the library scan complete before your files will be visible in the library. If you select library you should see at the bottom when the last scan update was completed.
