Hey guys, its my first post, so I’m hoping this is the right way to do this.
I have a samsung tv, which only has HDR10+. I have a bunch of hybrid files which only detect as DV (files with the DV metadata removed will show the HDR10+ in the player statistics).
I cannot for the life of me, get the HDR10+ to be on the TV. I have turned Dolby Vision off in the infuse settings (which was suggested in this earlier article, Unable to play HDR10+ from a dual profile DV/HDR10+ files ), but for whatever reason, in the player statistics it still shows DV.
I have included a screenshot showing the player statistics displaying DV even with DV off (hopefully that makes sense).
Originally I thought the issue was with Plex (I use Plex via infuse on my apple tv), but even after adding my NAS files to infuse directly as a network share, the same issue arises.
Here’s the mediainfo snippet from the hybrid file its most recent occurred with (though, for the record, I have never seen infuse detect HDR10+ from any hybrid file)
Video
Format : HEVC
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile A, HDR10+ Profile A compatible
I unfortunately have a bunch of both DV and HDR10+ mixed devices, so just removing the DV data for all the hybrids isn’t an option.
