Everything went smooth, but when connecting to the tv and starting up first time, no FC logo appear?
What going on here?
What going on here?
Tried to run aTV Black 2.4 and this also went fine.
When I startup the atv2 at the tv, it cannot connect to network it says, and therefore onle 3 icont appear.
If I look into my router it shows up at connected with an internal ip and everything?
This is very odd. I will try the Seas0npass over again to find out if this helps.
Plz shout if you know what this is all about.
Does everything work ok when not using wifi?
