I have no problem to play MKV with DTS audio (whish is great)
I tried to remux the mkv to M4V, but for some reason I can’t get any DTS sound (only stereo from the AAC audio stream)
mediainf.
Allmänt
Fullständigt namn : /Volumes/video/Movies/A Good Day to Die Hard/A Good Day to Die Hard (2013) 720p DTS x264 BluRay.m4v
Format : MPEG-4
CodecID : M4V
Filstorlek : 3,47 GiB
Duration/String : 2 h 12 min
Generell Bitrate : 3 755 Kbps
Kodningsdatum : UTC 2013-05-12 17:10:12
Taggingdatum : UTC 2013-05-12 18:13:46
Video
Format : AVC
Format/ : Advanced Video Codec
Format_Profile : High@L4.1
Format_Settings_CABAC/String : Ja
Format_Settings_RefFrames/String : 5 frame
CodecID : avc1
/ : Advanced Video Coding
Bitrate : 2 044 Kbps
Bredd : 1 280 pixlar
Höjd : 544 pixlar
Bildförhållande : 2,35:1
Bildhastighet (Frame rate) : 23,976 fps
FrameRate_Minimum/String : 23,810 fps
FrameRate_Maximum/String : 24,390 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Bits/(Pixel*Frame) : 0.122
StreamSize/String : 1,89 GiB (54%)
Skrivande bibliotek : x264 core 129 r2230 1cffe9f
Kodningsinställningar : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Språk : Engelska
Taggingdatum : UTC 2013-05-12 17:43:00
Audio #1
Format : DTS
Format/ : Digital Theater Systems
CodecID : A9
Bitrate : 1 509 Kbps
Kanal(er) : 6 kanaler
Kanalplatser : Front: L C R, Side: L R, LFE
Samplingstakt : 48,0 KHz
BitDepth/String : 24 bits
Video fördröjning : 84 ms
StreamSize/String : 1,39 GiB (40%)
Språk : Engelska
Audio #2
Format : AAC
Format/ : Advanced Audio Codec
Format_Profile : LC
CodecID : 40
Bitrate : 192 Kbps
BitRate_Maximum/String : 318 Kbps
Kanal(er) : 2 kanaler
Kanalplatser : Front: L R
StreamSize/String : 184 MiB (5%)
Språk : Engelska
Taggingdatum : UTC 2013-05-12 18:13:43
Text
Format : Timed text
MuxingMode : sbtl
CodecID : tx3g
Duration/String : 2 h 7 min
Bitrate : 51 bps
StreamSize/String : 47,4 KiB (0%)
Språk : Engelska
Kodningsdatum : UTC 2013-05-12 17:10:13
Taggingdatum : UTC 2013-05-12 18:12:50
