no cover art for tv shows
my cover art wont show up in my tv show folders, for some reason it does show in my recently watched menu so it must be there somewhere, but i’ve tried reloading the metadata and all and have had no luck.
Have you made sure that the ‘type’ for the folders containing TV shows is set to say they are TV (set by holding doen the OK button when on a folder).
Yes, I’ve made sure that is correct, all the metadata loads correctly, just not the cover art
