Hi, I have some old TV shows with are encoded with AAC as audio codec.
If I start playback of an episode, I have no audio. If I fast forward or rewind a few seconds, then audio works.
Here are the Infos about the audio track from “MediaInfo”:
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec-ID : A_AAC-2
Duration : 46 min 3s
Channels : 2 Channels
Channel layout : L R
Samplingrate : 48,0 kHz
Frame Rate : 46,875 FPS (1024 SPF)
Compression mode : Lossy
I have this problem on Apple TV 4K with tvOS 14.7 and Infuse 7.0.9
