No audio on VOB files
I just installed the latest upgrade, 1.3.
When I attempt to play a VOB file, which previously worked, I now get a
message stating something like the playback quality may not be very good
with this file type.  I continue to play it; the picture is fine, but there is no audio.
I have tried putzing with the different audio options, but can not get any audio
out of my VOB files.
Is this a known issue? Is there an option I can change? Can I regress to 1.2?
Thanks.
Is this a true .vob file or was it converted to something else?
Which version of AppleTV software are you running?
The VOBs are those of several of my DVDs I created using DVD shrink.
The Apple TV is at 4.4.4
However, I just realized something:
A light on my stereo comes on when it is receiving DTS/Dolby
So, the audio must be making to the stereo, but no there is no sound.
My HDMI goes from my Appple TV to the TV.  There is a Digital Audio out at the back of the TV
and that cable goes to the Digital Audio in of my stereo.
So, I cranked up the volume on the TV, which is always off, and there is sound!
So, not sure where the problem lies. Must be my TV.  I tried various audio settings in the Apple TV
to no avail.
I’ll have to try plugging an optical audio cable to the input of my stereo.
I doubt it if is a problem with aTV flash.
Just a quick update. My files are on a shared SMB folder on Windows.
My Boxee Box will play the same VOB, with audio, however no Dolby
or DTS.
