Greetings,
Using Infuse in iOS 17.4.1, on an iPhone 11, audio will not work for this specific file. It works fine on Apple TV and macos (desktop app).
Many thanks in advance.
$ mediainfo Dune\ Part\ Two\ \(2024\)\ \[imdbid-tt15239678\]\ -\ \[WEBDL-2160p\ Proper\]\[EAC3\ Atmos\ 5.1\]\[8bit\]\[h265\]-FLUX.mkv
General
Unique ID : 278516061675644567579797480291016962922 (0xD1883E08833C8247CAB2E4671CFCF36A)
Complete name : Dune Part Two (2024) [imdbid-tt15239678] - [WEBDL-2160p Proper][EAC3 Atmos 5.1][8bit][h265]-FLUX.mkv
Format : Matroska
Format version : Version 4
File size : 18.2 GiB
Duration : 2 h 46 min
Overall bit rate : 15.6 Mb/s
Writing application : mkvmerge v83.0 ('Circle Of Friends') 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1
Video
Format : HEVC
Format profile : Main@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 14.6 Mb/s
Width : 3 840 pixels
Height : 1 600 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.099
Stream size : 17.0 GiB (93%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : 16 ms
Stream size : 917 MiB (5%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : Yes
Forced : Yes
Text #2
Format : UTF-8
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Title : SDH
Language : English
Default : No
Forced : No
Text #4
Format : UTF-8
Language : German
Default : No
Forced : No
Text #5
Format : UTF-8
Title : Latin American
Language : Spanish
Default : No
Forced : No
Text #6
Format : UTF-8
Language : Hebrew
Default : No
Forced : No
Text #7
Format : UTF-8
Language : Hungarian
Default : No
Forced : No
Text #8
Format : UTF-8
Language : Korean
Default : No
Forced : No
Text #9
Format : UTF-8
Language : Lithuanian
Default : No
Forced : No
Text #10
Format : UTF-8
Language : Norwegian
Default : No
Forced : No
Text #11
Format : UTF-8
Language : Portuguese
Default : No
Forced : No
Menu
00:00:00.016 : en:Chapter 01
00:09:15.237 : en:Chapter 02
00:21:29.930 : en:Chapter 03
00:29:31.037 : en:Chapter 04
00:40:08.924 : en:Chapter 05
00:50:40.931 : en:Chapter 06
01:00:34.150 : en:Chapter 07
01:09:54.543 : en:Chapter 08
01:19:40.504 : en:Chapter 09
01:30:39.955 : en:Chapter 10
01:39:06.087 : en:Chapter 11
01:49:35.883 : en:Chapter 12
01:59:40.446 : en:Chapter 13
02:10:24.632 : en:Chapter 14
02:18:50.304 : en:Chapter 15
02:24:19.258 : en:Chapter 16
02:37:45.815 : en:Chapter 17
