Hi.
Every time i try to update nitotv i got this error(E:dpkg was interrupted,you must manually run dpkg cunfigure i correct the problem).
How do i do that?
Thanks.
im also having that same problem
You will need to ssh to your ATV as root and run the command the error states at the command line.
I had the same problem… solution to this was simply by running following commands>>
apt-get install package
It will show some error so run next one >>
apt-get dist-upgrade
now you are all done hope this will help … PEACE
