Hello,
i have problems with my .avi files....when i start playing the videofiles (.avi) in nito the sound is scratching like a needle scratches over vinyl.
any ideas what happened?
if i play the same file on my imac.....no prob!
cheers,
pit
Hello,
cheers,
pit
is your AppleTV connected to an AV receiver? You can try disabling the 'AC3 Passthrough' option found in the Maintenance --> Settings menu.
I am having the same issue. I have my AppleTV connected to a Sony amplifier which is capable of doing the AC3 decoding.
I noticed that divx files with mp3 sound work flawless with NitoTV, but with AC3 sound it's just a high screeching sound.
Playing the same xvid with AC3 sound with sapphire works though. The same for XBMC.
After playing the file with sapphire for a few seconds and opening the file with NitoTV gives me the same result. NitoTV then plays the file without problems.
So i figured it might be a problem with NitoTV. I just did a factory reset op my ATV to 3.0.2 and loaded ATVFLASH 4.2.1
I just did an install of perian and nitotv. Nothing else. Problem is still there. A high screeching sound in playback.
How do i fix the AC3 sound to properly decode it on my amplifier using NitoTV?
I must have tried al settings by now.
thanks
