You will want to ensure the ‘Maintenance’ item is up-to-date. After the update is installed (and AppleTV restarted when prompted) any other updates should install properly.
You will want to ensure the ‘Maintenance’ item is up-to-date. After the update is installed (and AppleTV restarted when prompted) any other updates should install properly.[/quote]
guardianmax…Are you saying to install the Maintenance update first and after restarting the AppleTV, then install the Nito 0.9.2 update? :?:
guardianmax…Are you saying to install the Maintenance update first and after restarting the AppleTV, then install the Nito 0.9.2 update? :?:[/quote]
Yes, your best bet is to always install the Maintenance update first. This will ensure you are running the latest version of the Maintenance application which handles all the downloads/updates.
I’m having the same issue with the NitoTV update, it’s still saying i need to update even after i get the latest version of maintenance. any help would be very much appreciated.
